Apr 24, 2018 #1 N ndequeiroz Junior Member level 3 Joined May 11, 2017 Messages 25 Helped 0 Reputation 0 Reaction score 0 Trophy points 1 Activity points 201 Hi, How to insert more than one via to ground in a microstrip line on ads? I'm trying to ground properly this via, but i don't know how do that... And is my via correct? I used the VIA GND component... Thanks
Apr 26, 2018 #2 V volker@muehlhaus Advanced Member level 6 Joined Apr 11, 2014 Messages 3,189 Helped 1,071 Reputation 2,146 Reaction score 1,138 Trophy points 1,393 Activity points 20,263 What are you trying to do? If this is for Momentum EM simulation, you can copy this via instance, or draw objects on a layer that you map as via in the Momentum substrate file.
