This charger can not give you an output more than 6volt because the secondary winding is desinge for that voltage,except you will increase the secondary winding your self.
zener value=? ,which contected though c845 & zener value=? ,which contected though 13003.
my rqerment is ... i want it opreting volt 80v to 500 v
pl help me . also need transformer detials
You dont have to make any changes from the circute the only thing you will do is to increase your secondary winding, except you want to increase the power,then you have modified the circute.
---------- Post added at 22:52 ---------- Previous post was at 22:40 ----------
Sahu, you can not used this diagram for the specifications you mention above,i suggest you find a suitable bulk converter circute for your requirement.
You only have to change the zener. I have test a lot of times and work perfectly.
Another mobile chargers (chinese chargers), work with feedback, with a zener and an optocoupler (in the secondary), you only have to make the same, change the zener 5,1 V, and put a 12 V, or 9 V or 15 V, depending of the voltage you want to obtain. More than 15 V is dangerous for the charger.
