It can
You can slow it down if the light media's temperature is nearly 0 kelvin. You can increase the speed a bit if the energy is so high, and its so hot, as hot as the supernova blast.
If you sit on the foton and start pedaling you may increase speed of foton up to five times the speed of light, than you go around the Earth and return to your starting point, and what will you see??? Your self before you started pedaling And there is your time travel)))))
how about superconductor, it can make electric voltage flow so fast.
or anyone aver heard Einstain theory, he said if an object move very very veryyyy fast the object will flow trought the space and time, just like "Back To The Future" movie
"Cerenkov Radiation is electromagnetic radiation emitted when a charged particle (such as a proton) passes through an insulator at a speed greater than the speed of light in that medium." https://en.wikipedia.org/wiki/Cerenkov_radiation
