I have a question regarding the gain optimization of an amplifier
The output gain of a standard differential amplifier can be written as
G=gm1*(r02||r04)
here r02 and r04 are the output impedances of the transistors
Therefore, it is often said that the length of these transistors should be large so that their output impedances are high
But I am thinking which one is dominant in this equation, r02 or r04?
If r04 is dominant, then I only need to increase the length of M4
Otherwise, if r02 is dominant, then it is allowed to use small length for M4 and I only need to use large length for M2.
The same question also applies for a single input amplifier stage, I am not sure if I should optimize the output impedance from the amplification transistor or from the load transistor?
If you put source resistors in series with the sources of all fets, the output impedance will increase, but the gain will decline. If you put source resistors on 3 and 4 their output impedance will increase and the gain may go as much as 2x higher.
Degenerated current mirrors are an option, but rarely used in CMOS design due to resistor matching problems, I think. A cascode current mirror is the usual methode, if high output resistance is intended.
My previous posted first guess wasn't quite right, I forgot, that the differential pair output resistance is about doubled compared to a current mirror with same transistor parameters and Id.
I think, without modification of the current mirror, Ro,4 will be about half of Ro,2, in so far, Ro,4 is "dominant" respectively the first candidate for improvement.
thanks, I am also quite interested to know why R04 is about half of R02?
Their currents are the same, so the output impedance would be mainly dependent on the length of transistors. So doesn't it depend on different sizing of 2 and 4?
You should be able to see operating point Rout or gDS-es
in your simulations, and determine for yourself which FET
is dominating the parallel result.
Note that if either FET gets close to linear region the
result goes in the tank. The smaller the FET width, the
more Vgs at either end and the narrow the non-lousy
region becomes. Running more L does not help if this
is your problem.
Running more W and shorter L will lower Vgs for a given
tail current and make the FETs have more range in
saturation, but you will be more at the mercy of lambda.
You should figure out for yourself whether you are seeing
a saturation-region type of Rout or not, so you know
what's driving your result.
As you said in your first post, Rout is ~ro2||ro4. This is the correct one and as you said, in chapter five of razavi's book, you can find that Rout is ro2||ro4 ( equation 5.28 ) .
