How to improve the linearity of an op-amp.I think there should be
many methods,but I don't know it clearly.
Anyone can show me the methods used commonly?
Or some paper about it.
At the first All you tranasistors must be in saturation. Non-lineriaty caused with changing output resistance of transistor. This occur even transistor in saturation. Because MOS has length-modulation effect. As sad surianova, you mast use local feedback to stabilize operation points. Output stage added a lot of non-lineriaty.
