How to improve PSRR for this kind of bandgap?
anhnha
Full Member level 6
Full Member level 6
I am using this kind of bandgap for my LDO.
The problem is that PSRR is very bad. It is only -40dB at DC. I need about -80dB at DC.
Could anyone suggest some methods to improve PSRR?
My op amp has 94dB gain so I think that is not the op amp problem.
Thanks.
A usual first step would be to analyze where in the circuit the PS influence is generated. As a first guess, I would suspect MOSFET output impedance, but you should measure the cause in your simulation.
Text book circuits often show cascaded current sources.
Reactions: anhnha
    anhnha
Thank you.
How should I analyse the cause?
Could you show me how to connect cascaded current sources?
I can't find the cascaded structure for this kind of bandgap.
Also compensate the opamp using cascode compensation technique instead of simple cuting bandwith by capacitor connected to ground/vdd could improve your psrr.
Reactions: anhnha
    anhnha
Thank you.
Did you mean that cascode compensation doesn't decrease the bandwidth?
Thanks. I am using folded cascode amplifier without any compensation.
I think I need to increase gain bandwidth of the amplifier.
