libertador
My post-graduate thesis is wideband open loop buffers/amplifiers. Hence, linearity is the most important spec. All of the papers that i found are about linearization techniques like degeneration resistors. Effects of dimensions that MOS widths/lengts, emitter area, resistors values or bias currents, voltages were not mentioned anywhere. So I determined this values only from simulation results.
Do you have any clue that to improve linearity not only with basic linearization techniques but also dimensions? Also do you know any paper or notes about this issue?
Thanks All.
PS: If you want i can add cicuits that i have designed.
Thanks All.
