How to import the GDSII file of inductor to ADS momentum?
wireless man
Full Member level 1
ads gds2
How to import the GDSII file of inductor from Cadence to ADS momentum? I want to do some modifications in Mom. Thank you all.
ads gds import
See ADS momentum import options available.
    wireless man
ads import gds
Open a layout, fo to file--->import. you will get menu for importing from GDS2, dxf and so on.
select the GDS2 option , select the file, select the layer file name and press ok.
it takes a while and updates the layout file and you can find the GDS file in ADS.
    wireless man
momentum *.lay file
How can I get the layers file name ? Thanks.
ads import .gds
Create a empty text file in explorer.
Let say "layer.txt", then rename the extension to lay to become "layer.lay"
Now you use ADS to pint this file.
Its done.
Re: How to import the GDSII file of inductor to ADS momentum
its simple procedure.
just take ADS help or search in google.
you will find some ppts describing complete procedure.
I dont have cadence, so i can not tell you about it.
but ads importing is simple
    wireless man
