i have datasheet of HXTR3675 FROM HP (BJT TRANSISTOR),I WANT TO IMPORT IT IN ads WHATT I DO ,IF THE S PAR. FILE NOT FOUND BUT I HAVE S PAR.DATASHEET PAPER.
REGARDS
What filetype do you have? If it is *.s2p file. you can use 2port model in ADS data item.And you should have a correct path with you data file.
It you don't have s2p files. you can write a s2P file manually.There is a example in ADS2003/EXAMPLE/tutorial/Advckt .I can not remmember clearily , it is something about how to use DAC( very useful database in ADS).
