How to import data for VHDL testbench for 1024 point FFT in Xilinx Ise 9.1i?
dhawalkadao
Junior Member level 1
I am implementing a 1024 point FFT using Xilinx ise 9.1i. Is there a way I can import the data for test bench automatically, using Matlab or any other text file.
Regards,
Dhawal
Xilinx Ise 9.1i
Which language is your test bench? Most languages provide file I/O function for reading and writing data files during simulation. For instance, Verilog provides $fopen, $fgetc, $fread, $fscanf, $fclose, and others that are similar to C functions.
Re: Xilinx Ise 9.1i
Thanks for the reply. The test bench is using VHDL. I am using VHDL to implement my design.
Regards,
Dhawal
Re: Xilinx Ise 9.1i
Hi !!!
You should look into Edit-> Language template
VHDL-> Simulation construct-> assertions & functions -> file I/O -> read:write to a file
Here are listed all the functions that you need....
Good luck
Re: Xilinx Ise 9.1i
Thank you very much I will try that out. Is there a document which has information related to this.
Regards,
Dhawal
