How to import an input source into ADS?
iVenky
Advanced Member level 2
College Station, Texas
I have a setup for measuring the EVM for 3GPP WCDMA data, as shown below
The question is I want to replace the test signal from a signal obtained in virtuoso (let's say I have the .csv file for the signal). Could you please tell me how to import that and make it work on ADS?
Thanks!
I don't know what you want mean by virtuoso and what data you mean by ".csv" at all.
However I assume thay you have two asciil data files, Idata.csv and Qdata.csv with time as independent variable.
Use https://edadocs.software.keysight.com/display/ads2009U1/TimedDataRead
You can modify Idata.csv and Qdata.csv to TIM Format.
Idata.csv -> Idata.tim
Qdata.csv -> Qdata.tim
You can use Complex number data in TIM Format.
So you don't have create two TIM files.
Just one file IQdata.tim
Also see https://www.designers-guide.org/Forum/YaBB.pl?num=1193043253/3#3
BTW, do you understand a meaning of arrow's color in Keysight-Ptolemy ?
And do you understand concept of SDF and TSDF in Keysight-Ptolemy ?
