Sep 22, 2005 #1 M moisiad Member level 4 Joined Mar 31, 2004 Messages 71 Helped 2 Reputation 4 Reaction score 1 Trophy points 1,288 Location GREECE Activity points 719 verilog netlist to schematic Hi I am using AMS simulator from Cadence Enviroment. My problem is that i have a verilog netlist and i want to make a symbol from it ,in order to import it in my schematic. How can i do this? thanks
Sep 22, 2005 #2 F flushrat Full Member level 3 Joined Jan 25, 2005 Messages 180 Helped 23 Reputation 46 Reaction score 8 Trophy points 1,298 Activity points 1,532 import verilog to schematic file-import-verilog
Sep 25, 2005 #3 L limingchou Member level 3 Joined Aug 24, 2005 Messages 57 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,286 Activity points 1,711 first, u set a function with the net second, u save and quit it, the system will remind u set the symbol.
Sep 27, 2005 #4 A andy2000a Advanced Member level 2 Joined Jul 18, 2001 Messages 597 Helped 14 Reputation 28 Reaction score 8 Trophy points 1,298 Activity points 5,298 if you use Cadence composer 1. select verilog-in 2. select "symbol" for your gate netlist then you will get synthesis gate level netlist but verilog-in circuit is complex for me .. trace synthesis gate netlist circuit is difficult
