Hello,
I have generated a signal in Matlab, and now I want to use it as voltage source for a spice circuit.
Is there a way to import the signal in Pspice?
Export that as csv file. and use configure a file base stimulus in PSpice and configure exported data from MATLAb as input file to stimulus source. You may need to modify the exported data a bit - like adding appropriate header etc to make it valid stimulus
