Register Log in
How to implement two compliment circuits using sequential circuit?
MSRA
Full Member level 2
NED Pakistan
How to impliment 2's compliment circuit using sequential circuit...?
dineshbabumm
2's compliment
A simple logic wil be to implement it directly as we do in straight forward hand calculations..
First complement every bit using an inverter and feed it to shift registers(if you want 4 bit,then use 4 shift registers..).. Now they wil be storing the 1's complement in them.. Feed it to an adder with the 1's complement as one input and 1 as another input.. The adder result wil be your 2's complement!
MSRA
Full Member level 2
NED Pakistan
2's compliment
is it the whole sequential procedur.....?
A.Anand Srinivasan
Advanced Member level 5
India
Re: 2's compliment
ya that is the required sequential circuit... 2's compliment is just 1's compliment plus 1....
dineshbabumm
Re: 2's compliment
Yes it is the whole sequential procedure..
cydi
Full Member level 3
2's compliment
If you are talking about an ADC output, then the matter is different. If you want to find the rep for any number, for seq circuits, the way to go is compliment all and add one...
Kral
USA
Re: 2's compliment
MSRA,
One way:
Shift the original number LSB first. The bits are unaltered until the bit after the first "1" is encountered. All subsequent bits are complemented.
Regards,
Kral
suru
Full Member level 3
2's compliment
first invert and then use adder circuit to add 1.
alam.tauqueer
Full Member level 2
2's compliment
1). Start shifting from LSB bits unaltered until the first "1" is encountered.
2).All subsequent bits are complemented.
suru
Full Member level 3
2's compliment
through VHDL coding also can be done.
simple code.
signal x;std_logic;
begin
x<= not y;
x<=X+'1';
rakesh_vnit
Member level 3
india
Re: 2's compliment
as it is a sequential input...u cant take 1's complement n then add 1...
so follow this..
1. start from LSB go left until u encounter 1, leave all the inputs as it is...
2. complement all the bits after the first one...
it will give u 2's complement...while workin sequentially...
roahan_ramesh
Newbie level 5
Chennai, India
Re: 2's compliment
One way to do it is the following :
1. Using an X-OR gate (it is a controlled inverter) pass logic 1 into one pin and the data (say pin B) in the other if you want to invert the data. If you pass logic 0 then no inversion occurs.
2. Then using an adder circuit using add 1 to the output from the X-OR gates and apply 0 to the other input (say pin A)
3. This way you will have an adder/subtractor circuit.
Toggle Sidebar
