How to implement the filter give in Z transform using matlab
rrajbe
Newbie level 1
Tamilnadu/India
Good morning to every one. . .
I am very new to this forum and not much expert in DSP field too. . .
I am trying to implement a IEEE paper named "A New Delayless Subband Adaptive Filtering Algorithm for Active Noise Control Systems" published in IEEE TRANSACTIONS ON AUDIO, SPEECH, AND LANGUAGE PROCESSING july 2009.
I have not done any such projects before and so i am strugling where to start and how to implement the given details.
This project is all about the following
1) A full-band filter that filters the input signal.
2) Decomposition of input and error signals into subbands.
3) Decimation in subbands.
4) Adaptive filters working in subbands.
5) A weight stacking method to combine all subbands weights into a full-band filter.
These are the details of a filter specification given in the paper. Could any one please help me to implement this in the matlab please?
x(n) is the input signal which is to be filtered into M subbands named
X'k(n)
where K ranges form 0 to M-1, using a analysis filter bank h(z) with a decimation factor D.
Filter h(z) is given by
h(z)=[ H0(z) ]
| H1(z) |
[ Hm-1(z)]
Where Hk(z) is the transfer function of Kth subband.
Given the low pass prototype filter for filter banks is
H0(z)=1+(Z)^-1+(Z)^-2+.......+(Z)^-M+1
The resulting filter bank is the simplest FIR filter perfect reconstruction filter bank which is made by
Hk(z)=H0(z.exp(-j*2*pi*k/M))
with a frequency response of
H0(exp(jw))={ M , when w=0;
{exp(-j*w(M-1)/2sin(wM/2)/sin(w/2)) , otherwise;
M is given about to be 16
D=M/4
For this proposed UDFT modulated filter banks, h(z) is defined by
h(z) = (1/M)F*[1 , (Z)^-1 , (Z)^-2 ,. . ., (Z)^-M+1] (transpose)
Where F is the DFT matix of order M. The central frequency of bandpass filters Hk(Z) are located at
wk=2*pi*k/M for 0 ≤ k ≤ M-1.
This filter can be realized by tapped delay line of length M followed by an inverse FFT block.
divyasagar
Newbie level 3
did u get a solution? that will be of great help to me as my problem is also similar
