How to implement PCI-Express ?
vlsi_whiz
Full Member level 4
Penang
I want to implement the PCI-express functionality , like in PCI we had the Master/Target interface. In PCI-e however, the spec talks about PCI-e endpoints and switch fabric! How do I go about implementing PCI-e functionality ?? Any suggestions??
Some guides on Design of ETX and support relating to PCI-Express is available in the following link.
Good luck
Added after 2 minutes:
Also two books from intel on the subject are available.
This link is will take to the intel the books on design of PCI express
https://www.pciexpressdevnet.org/techbook.asp
Added after 13 minutes:
Also this doc helps u to understand how to dessign High bandwidth Interconnect using the Virtex-5 LXT PCIe Endpoint Block which is a configurable Single-chip Solution
Hi
First let me now ..what u want to implement .is than an endpoint/Root complex . u want to implement a BFM or RTL IP . I suggest u to read Mindshare and then start to implement . If u have any doubts feel free to ask .
the PCIE root complex is like a host bridge;
the PCIE endpoint is like a normal PCI device;
the PCIE switch is like a PCI to PCI bridge;
there are many similar concepts between PCI and PCIE. but PCIE uses packet for its transactio.
you can refer the book :
PCI Express System Architecture
By MindShare, Inc , Ravi Budruk, Don Anderson, Tom Shanley
