Aug 24, 2012 #1 P Prashanthanilm Full Member level 5 Joined Aug 24, 2012 Messages 302 Helped 36 Reputation 72 Reaction score 36 Trophy points 1,308 Activity points 2,950 Hello, Can you give the information regarding FIFO and how can it be implemented using block,schematic,Program,cadence or any other tool.Basically I am on that project. Thank you. "Sharing makes you more powerfull"
Aug 26, 2012 #2 J jeffrey samuel Advanced Member level 4 Joined Jul 23, 2012 Messages 1,092 Helped 107 Reputation 214 Reaction score 107 Trophy points 1,363 Location chennai,india Activity points 6,373 Re: Revealing more on FIFO it is like in a queue where you have to wait till it is your turn the point is first in first out simply represents the data ip is stored 1 behind the other the serial data can be accessed as a serial kit as in the flow diag hope it helps
Aug 27, 2012 #3 P Prashanthanilm Full Member level 5 Joined Aug 24, 2012 Messages 302 Helped 36 Reputation 72 Reaction score 36 Trophy points 1,308 Activity points 2,950 Re: Revealing more on FIFO Do you have the Block of FIFO used??
Aug 28, 2012 #4 J jeffrey samuel Advanced Member level 4 Joined Jul 23, 2012 Messages 1,092 Helped 107 Reputation 214 Reaction score 107 Trophy points 1,363 Location chennai,india Activity points 6,373 i am yet to try it prog if i finish ill post it to you
Aug 29, 2012 #5 P Prashanthanilm Full Member level 5 Joined Aug 24, 2012 Messages 302 Helped 36 Reputation 72 Reaction score 36 Trophy points 1,308 Activity points 2,950 thank you.I have many doubts on fabrication,digital electronics.can u mail me so its easy to communicate.my id is prashanthanilm@gmail.com. thank you
