How to implement capacitive slider switch with a MCU?
ColdFire
Member level 3
Member level 3
Capacitive Slider Switch
Hi All,
My project requires a capacitive slider switch, anyone know how to implement this with a MCU? Currently my project is using PIC. Please advice. Thank you.
Regards
Re: Capacitive Slider Switch
hi..what's a capasitive slider switch? do tell..
What range of capacitance do you need?
qprox has such a QSLIDE™ TOUCH SLIDER
Maybe you can use it.
I've already worked with qprox and can say it's very tricky to solve all EMC problems (a slider is a long antenna). By a slider an other problem is what's to recognize when you press two finger on the slider?
Gomez
Hi All,
Thank you for the information. I am hoping to implement the capacitive slider switch using my current MCU which is a PIC. I am thinking to make the slider onto the PCB but I think this is very tricky, there will be noise and other issue. Not sure if anyone have any other way of implementing. Please help if anyone has. Thank you very much.
Regards
...read qprox application notes, they are using this kind of switches in noisly environments...
//a
