How to implement bitwise ROTATION in C
CM600
Member level 3
BG
bit rotation in c
Hello,
I am using IAR ARM C compiler, is there a library function for rol or ror ?
c bit rotation
Hi CM600,
You can try << for rol and >> for ror.
regrads,
c bit rotate
hi!
u caneasily do it by using of bitwise operators.
rag_perfect
bitwise rotate c
The >> and << operators are for shifting not for rotation
bitwise rotation in c
to rotate a byte by n bits to the right:
a = (a >> n) || (a << (8-n))
you probably want to make your code more general (don't hardcode '8').
