how to implement 240AC to 240DC converter
nismo87
Kuala Lumpur
Does anyone know how to implement this device?
shamikrudra
Full Member level 5
Kolkata, India
Re: 240AC to 240DC converter
simply make bridge rectifier using four 1N4007 diode to convert 240V AC to 240V DC.
rajudp
Advanced Member level 2
India
if you want isolation from mains use a transformer,
ark5230
Advanced Member level 3
India
If you use filter capacitors for smoothing of DC, it will increase voltage at the output by a factro of 1.41 thus some voltage divider or alternate can be resorted if the 240 AC to 240DC is critical.
Raoof
karesz
Advanced Member level 5
EU
These means, that you must have a DC/DC Converter with Dc Input of ca. 300-350V:).
Check pls **broken link removed** has a good designer Sw (downloadable) & rich ApplNotes...
"PI Expert® Suite v7.1 simplifies the design of off-line power supplies and DC-DC converters based on PI products."
ST is another good source of ApplNotes.
K.
Tahmid
Silicon Valley, California, USA (from Dhaka, Bangl
When you rectify the AC voltage to DC and add filter capacitors, you have a DC voltage that is approximately 1.414x the AC input. So, you have a 1.414 * 240 = 339VDC supply.
Use a DC-DC converter now to convert this to 240VDC. You can use TOPSwitch from Power Integrations, VIPERswitch from ST Microelectronics or a discrete circuit with UC384x and MOSFET.
An alternative is to drop the 240VAC to 170VAC using a transformer and then rectifying this to DC and filtering it. So, you will have a 170 * 1.414 = 240VDC supply.
The latter method would be much easier, but maybe more expensive / bulky, depending on your power rating.
The first method would be a little trickier, but not very difficult nonetheless, and will be lightweight and cheaper, but again this depends on your power rating.
Hope this helps.
Tahmid.
