How to have a variable filename in the fprintf statement?
Old Nick
Advanced Member level 1
hi,
I'm writing software to rip data from a camera we designed, I need to take multiple images to manipulate in matlab. I am currently using fprintf to write files which is working fine.
But what I want to do is take 100-1000 frames and write each image to a file, incrementing the name of the file for every image.
Obviously a for loop would be ideal, but how do I have a variable filename in the fprintf statement.
Cheers for any help.
Nick
Re: fprintf
fprintf takes FILE pointer as an argument. That means that you will have to close previous file and than open a new one with fopen. fopen will taka a file name which a string, and can be constructed using sprintf.
    Old Nick
Re: fprintf
Cheers for that,
But what I need to know is how to change the name of an output file in a for loop.
I should have made it more clear that I already know how to close and open files, it is the renaming in a loop that I need to know.
Re: fprintf
I would use sprintf and the loop index (appended to the filename), something like:
#define MAX  100
#define BASE_FILE "myfile_"
char filename[255];
int  i;
FILE  *f;
for (i=0;i<MAX;i++) {
    sprintf(filename,"%s%03d",BASE_FILE,i);
    f = fopen(filename);
    if (f) {
        // write data
        fclose(f);
Is this what you had in mind?
    Old Nick
