[PIC] how to handle multiple interrupt in PIC using Mikro C software
phrbob93
Member level 1
Member level 1
Jalandhar, punjab
here i am programming PIC16F877a Micro controller for interrupt
i did a program of handling external Interrupt and it is working correct, for the service routine of External interrupt i was instructed to add a ISR function(can be of any name) with interrupt keyword,
for e.g. i use
void interrupt external(void) // interrupt keyword followed by any name for function
//ISR code.............
now i want to do a program in which there are multiple interrupt lets say i want to program external interrupt and timer interrupt in the same program..
for that i will use
void interrupt timer(void){
so my question is how compiler will distinguish between timer ISR function and external ISR function ??
You usually have only one isr function and you check the interrupt flags individually to see which interrupt was triggered:
void interrupt(){
//An interrupt was triggered
if(INT0IF == 1){//Check if external interrupt event occured
// place code for handling INT0 interrupt here and clear interrupt flag
if(T2IF == 1){//check if TMR2 caused the interrupt
// place code for handling TMR2 interrupt here and clear interrupt flag
//Exit ISR
For ISR there is different interrupt vector handler for different interrupts you can check in its header file.
Correct me if I am wrong, but I don't think mikroc for pic16 has multiple handlers/identifiers for different interrupts and doesn't pic16 have only one interrupt vector? (He probably won't find isr vector defs in the device's header file)
In mikroC you can proably define multiple interrupt functions using the interrupt keyword, but you will probably have to check the interrupt flags to indentify which interrupt to service.
Reactions: ernpao
    ernpao
Although the original question has been already properly answered, a point that deserves some attention when dealing with multiple interrupts is related to the need of routine perform the treatment efficiently, being necessary to get out of the interrupt vector as quick as possible, in order to avoid that other interrupt events goes unnoticed.
Reactions: ud23
    ud23
