How to handle Lambda calculation and plotting?
ASICK
Junior Member level 3
san jose,ca
I dont know how to calculate the output res of the transistor in any configuration, as it involves Lambda(r=1/lamda*Id), is this a process parameter? I dont think so, as the plot changes depending on Vgs, right?? how to calculate or plot it? is there an easy way? or any other way to find output resistance of a transistor?? thnx
calculation of lambda calculation
just plot 1/slope of the Id-Vd curve of the transistor that will be the curve of the small signal output resistance. Lambda depends upon the biasing point and also the length of the transistor. You can find Lambda from ro if you want, but once you have ro you won't need Lambda.
lamda calculation
Lambda is not a process paramter in BSIM models. Only for wide w and l's lambda makes sense to compute. Using w aad l values in the near of the critical dimension lets vary lambda in a wide range.
However, lambda is taken to compute the rds (rout). So its's better to plot rout directly. Most simulators, so do Cadence, Mentor, ... save a simulation parameter rout or gout. make a paramter plot over different w, l and Ids!
    ASICK
Re: Lambda calculation
donnot use lamda any more
It not a constant
So if i need to know the rout of any transistor in a circuit without knowing lambda, what is the bestand easiest way in cadence? what kind of plot will let me know the approm value of Rout, so I can measure my gain and poles without having to know lambda?
Lambda calculation
plot ids-vds@vgs curve,then delta(ids)/delta(vgs),the do reciprocal operation.you will get rout curve
    ASICK
