HadesMahony
Newbie level 3
Hi!
Maybe one of you can help me...
I have a problem with a small project i'm working on.
I built a little analog synthesizer (nothing special, it can only
produce square-waves). A cool little thing, i think.
Now i want to add a Tremolo-Feature to it and i remembered
a tremolo-guitar-effect-pedal i built once. I don't need it
anymore, so i removed the pcb and tested it with my synth.
Because the tremolo was made as a guitar-effect, the output signal
doesnt fit my project. My synth is working with a simple small 8 Ohm/R Speaker.
When i tested it, it worked fine, but the signal from the tremolo-board was very low/quiet..
I have a link to the tremolo-schematic on GGG:
http://www.generalguitargadgets.com/pdf/ggg_eat_sc.pdf?phpMyAdmin=4a28f86a515b7883e7bc35a68d4e7b6d
..can someone tell me which parts/values
i can change to get the right signal from the output? ...remember, i am using a small 8 Ohm Speaker (0,5 Watt)...
Thanks a lot and sorry if my english is bad (i'm from germany)
HadesMahony
HadesMahony
