gaom9
Full Member level 4
I want to get the netlist for Hspice analog simulation from cadence composer Schematics.
I know I can get it through that: select hspices simulator and then chose Netlist- »creat final.
But the mos transistor of the schematics is from the sample lib, they have no bulk connector, so I can not do that in that way.
And then I use the way of "Export--CDL in CIW", but when I chose the kind of the netlist to analog (analog or digital), it failed. Then I use the digital netlist of it to make a analog simulation by hspice, but it failed again.
So I want to know the way to get the netlist for hspice with the transistor from sample lib, and when I use this netlist to make a simulation, what should I pay attention to?
This circuit was not designed by me. The circuit was finished before it came to me. What I should do is to simulate it through Hspice.
Thank you!
Best regards!
Thank you!
Best regards!
