How to get the inverse of matrix in vhdl
dksagra
Junior Member level 1
india
Hello,
I need your help urgently for calculating inverse of the matrix.
for example i need to calculate the inverse of the following A matrix where A is signed. how top do this? please help.
A:= ("0100", "0010")
Your matrix example is suspiciously vector-like. :p Or transpose vector, depending on the notation du jour. You know that inverse only works for square matrices, right? For non-square you get stuff like least squares and/or projections. As in left-inverse and right-inverse and all that. So a clearer specification might be in order.
What order matrices will the input be?
actually its a vector type...
A:=("01001010000001000010000000000000")
A is signed and 31 downto 0..its a 32 bit vector...
i have to take inverse of this...
Your mastery of confuzzlement is enviable!
Your current example A:=("01001010000001000010000000000000") is different from the previous example A:= ("0100", "0010").
Let's forget about VHDL for a moment. Purely in math terms, do you know what you want?
Because ... in your latest example A:=("01001010000001000010000000000000") is a 1X1 matrix with 32-bit signed matrix elements for which the inverse is fairly trivial. :p
