How to get the default value of static variable in C?
rameshbabu
In C the default value of static variable is zero, how we are getting it.
C
The compiler links in 'Start up code'.
The start up code initialises the system, such as static variables, global variables, constants, etc.
The start up code is usually a small assembler module which you can modify if you need to.
