How to get parallel hardware in simulation using case statment?
bharat_in
Member level 4
Till now, i was under impression that case statment will generate non-priority encoder hardware both in simulation and synthesis, but following coding shows that in simulation in works like proirity encoder... :-(
module m ();
wire [3:0] w1 = 4'b1101 ;
initial
begin
#4;
case(1'b1)
w1[0]: $display("0") ;
w1[1]: $display("1") ;
w1[2]: $display("2") ;
w1[3]: $display("3") ;
default: $display("Default") ;
endcase
end
endmodule
Output:
I guess, in this case it will have pre-synthesis and post-synthesis simulation mismatch.
Can anyone please explain, how to get parallel hardware in simulation using case statment?
case statement
initial will be ignored by synthesis tool and display also not synthesizble
try to write synthesizable rtl code
Re: case statement
What I know is that in VHDL, case statement is a sequential statement not a concurrent, is this the situation for Verilog?
Re: case statement
When u r talking about synthesis then #4 and $display should not be there in ur RTL.
After u have rectified this, u have should add parallel_case directive specifically for this condition as choice of case statement is variable here. write like this:
case(1'b1) //synopsis parallel_case
w1[0]:
case statement
copy your code here:
case(1'b1)
i think is ur case condition have some issue.
u try the case statement as follow:
case(w1) //<- here should be w1, not 1'b1
case statement
have you tried with synthesis directive on those
Re: case statement
for those who were asking for synthesizable module....
module m1(w1,a,y);
input wire [3:0] w1;
input wire [3:0] a ;
output reg y;
always @ *
begin
  case(1'b1)
    w1[0]: y = a[0];
    w1[1]: y = a[1];
    w1[2]: y = a[2];
    w1[3]: y = a[3];
    default: y = 0;
  endcase
end
endmodule
for w1 = 4'b1001 and a = 4'b0001. In simulation Y evaluates to 1'b1 as w1[0] is 1'b1 and it is having higher priority than others.
Now may question is, if i want to create parallel case in simulation that how can i create it. For synthesis i can specify parallel case directive, but then i will have post-synthesis and pre-synthesis simulation mismatch....
case statement
U can use constraint to avoid mismatches :)
Re: case statement
@shiv_emf
Please, tell me what kind of constrains should i use, in that case?
Re: case statement
Hi bharat_in,
Let me look at the problem from a straight fwd perspective.
One output Y, may get a value from either of 4 inputs a0, a1, a2, a3,
depending upon 4 other inputs w0, w1, w2 ,w3. OK?
ok 4to1 mux, but you have 4 lines to select(instead 2, which you normally have), i.e 16 input combinations to decide 4 choices for y i.e a0, a1, a2, a3?
4 choices aur 16 select combinations, bahut beinsaafi hai ye ;)
So to have an exact sim/syn match, you may want to re-write your case statement as
case w1
  4'b0001 :
  4'b0010 :
  4'b0011 :
  4'b0100 :
  4'b1110 :
  4'b1111 :
  default y = 0;
endcase
you decide under these 16 cirumstances clearly, what Y should get.
This is an absolutely parallel code, with no amiguity, and no sim/syn mismatches.
coding it in a way you have done, is technically correct, but is not very explicit, as to what exactly you are after.
Kr,
Avi
http://www.vlsiip.com
    bharat_in
Re: case statement
This is the way !
Hope this helps!
module m1(w1,a,y);
input  [3:0] w1;
input  [3:0] a ;
output y;
       assign y = (a[0] & w[0]) | (a[1] & w[1]) | (a[2] & w[2]) | (a[3] & w[3]);
endmodule
    bharat_in
