how to get inverted circuit from eagle
mana111
Member level 1
eagle invert mask
hi
i want to get an inverted picture from eagle software
anyone knows how?
thanx
tamerakshar
Full Member level 1
hi,
when you push the print button , the print menu pop out.
there you can see a check box called Mirror ( the first check box).
by printing your work mirrored ,the output image will be inverted.
but why do you want to invert it , while eagle prints images normally.
bottom side & top side is printed normally in eagle,no need for inversion.
if you still need help,just let me know :D
TeE ThE EdE
    mana111
mana111
Member level 1
hi
thanx but i mean somthing like this
tamerakshar
Full Member level 1
uhaaa , got you
after finishing your board ,from file menu choose export then image
select a name and check the monochrome check box then save it.
then open the image with windows paint and from image menu choose invert colors.
Voila , your image is ready:D
TeE ThE EdE
mana111
Member level 1
ok another one :)
how can i export the file for making green mask???
tamerakshar
Full Member level 1
hi,
wut do u wanna mask?
pads???
explain plz
mana111
Member level 1
i dont know if there is many types pf green mask
but it will cover the circuit except the tracks and pads i think
tamerakshar
Full Member level 1
hi,
tracks must be green masked ,only pads are left for soldering reason.
from eagle command toolbar choose the display button select everything but leave pads and vias if u've them in your design, then click change then ok.
now you have the pads pattern.
what you gonna do now is what you did lately,just export it as an image then print it as a monochrome and so on.
waiting for response.
TeE ThE EdE
    mana111
mana111
Member level 1
isn't there anyway to do it inside eagle
i think this way the size maybe effected
tamerakshar
Full Member level 1
hi,
no i think not
it won't affect the size
if u've doubts try using photoshop instead of paint.
TeE ThE EdE
tamerakshar
Full Member level 1
hi,
i think its my turn;
can u tell me a good way to apply the green mask with a good finishing look??
TeE ThE EdE
mana111
Member level 1
soory it's not me who do it
i made the design only
