[SOLVED] how to get gm/id plot vs vgs in cadence virtuso
ddis
Member level 2
Member level 2
hi all,
what we get from this curve ???????
whats the interpretation????
you can refer to this URL
go to T04 small signal model
To get gm/id plot you can setup a simulation with the schematic that is showing in the following figure.
Then you must to do a parametric simulation with Vgs as variable. After this, you can use the calculator tool in order
to read the gm and id of the component.
The interpretation is the following:
gm/id is a measure of the sensitive of the device with respect to its current polarization. With the results of
this simulation you can see that as the vgs increases the gm/id decreases, in other words, the sensitive of the
device (gm) to converte voltage (vgs) into current (ids) decreases for the same current polarization.
Best regards
Reactions: MFayek
    MFayek
