how to get course code from a hex file
Terminator Electricity
Member level 5
hi , I have a full project with a hex file ,,,,only a hex file ,,, but i want to slightly modify the project ,,,,, how could I do that ? how could I get the source code from that hex file ?
plz I really need help in this
brevor
Member level 1
Valparaiso, Indiana USA
To convert a hex file back into source code you need to use a disassembler program for the specific processor used in your project.
techie
Advanced Member level 3
Pakistan
Converting from hex to source is not easy and not accurate. Converting to assembly source is relatively easy but to convert to a higher level language is even more difficult. Also keep in mind that you can never recover the remarks etc. High level laguages also use optimizations which make it even more difficult to recover any source code.
Member level 5
"Converting from hex to source is not easy and not accurate. Converting to assembly source is relatively easy but to convert to a higher level language is even more difficult. Also keep in mind that you can never recover the remarks etc. High level laguages also use optimizations which make it even more difficult to recover any source code."
bummer ,, , I am very sorry to hear that
Added after 22 minutes:
I have this very interesting project , about an sms controlled system ,,,,
I want to understand it then be able to modify it ,,,,
If anyone can help me get its source code , or anyone have a similar project with a complete source code , plz tell me about it cuz I desprately need it
Member level 5
another link :
http://rapidshare.com/files/14840789/SMS_Controller.rar
and thanks in advance for everyone who would help ,,, and i am willing to give anything i can do in return
techie
Pakistan
My advice: Dont try to reverse-engineer the code. Try to write your own code. It might take longer but you will be able to understand better.
Member level 5
"My advice: Dont try to reverse-engineer the code. Try to write your own code. It might take longer but you will be able to understand better."
I am a complete beginer in the AVR
Is there any similar reference projects I can use if i would write my own code ? (in C language)
techie
Pakistan
There are many examples although it might be difficult to find the exact project. You can begin by making the PCB and then trying to communicate in C via serial port using AT commands. Once you do that, the rest should be quite good fun.
Member level 5
"then trying to communicate in C via serial port using AT commands"
could you explain this to me more plz
thanks
techie
Pakistan
Well, all communications to the phone are done via serial port, using AT commands. When you send a command to the phone, the phone sends a reply. What I mean is that you should first get this communication going. There are many examples to do that in C. I have not used the AVR but I find that there are many resources avaialable.
Member level 5
pic examples or resourses about this communication is very welcomed ,,, do you know where I can find any ?
techie
Pakistan
Microchip has loads of application notes. I am sure you would find many on serial communications.
