how to generate test pattern atpg in tetramax
avinashch
Member level 2
california, usa
i am trying to generate test pattern for the full adder but i am not getting anything out of it. it is reading the netlist but not giving any results.
it is giving N5 warning.
at the end of reading the netlist it gives
#modules=0, top-full_adder, #lines=29, cpu time=0.00 sec, memory= 0mb
is there anything else that i need to do to make it work??
here is my code for the adder:
module full_adder(input1,input2,carry_in,sum,carry_out);
input input1;
input input2;
input carry_in;
output sum;
output carry_out;
wire int1_sig;
wire int2_sig;
wire int3_sig;
assign int1_sig = input1 ^ input2;
assign int2_sig = input1 & input2;
assign sum = int1_sig ^ carry_in;
assign int3_sig = int1_sig & carry_in;
assign carry_out = int2_sig | int3_sig;
endmodule
the testbench is as follows:
module test_adder_1bit;
// Inputs
reg input1;
reg input2;
reg carry_in;
// Outputs
wire sum;
wire carry_out;
// Instantiate the Unit Under Test (UUT)
full_adder uut (
.input1(input1),
.input2(input2),
.carry_in(carry_in),
.sum(sum),
.carry_out(carry_out)
initial begin
// Initialize Inputs
input1 = 0;
input2 = 0;
carry_in = 0;
// Wait 100 ns for global reset to finish
#100;
// Add stimulus here
input1=1'b0;input2=1'b0;carry_in=1'b1;
#10;
input1=1'b0;input2=1'b1;carry_in=1'b0;
#10;
input1=1'b0;input2=1'b1;carry_in=1'b1;
#10;
input1=1'b1;input2=1'b0;carry_in=1'b0;
#10;
input1=1'b1;input2=1'b0;carry_in=1'b1;
#10;
input1=1'b1;input2=1'b1;carry_in=1'b0;
#10;
input1=1'b1;input2=1'b1;carry_in=1'b1;
end
endmodule
you must have a gate netlist to generate ATPG patterns.
Currently, Tetramax reads your code and doesn't see any scan Flip Flop then it generates nothing.
Regards,
Jerome
i tried it using a gate netlist but still it is not giving me anything. do i need to add some other things to my code. i tried a simple gate netlist as follows:
module circuit(a,b,c,f);
input a,b,c;
output f;
wire d,e;
and and1(d,a,b);
and and2(e,b,c);
or or1(f,d,e);
endmodule
but it still gives me the same results.
There is no Flip flop in your code. This is only combinatorial.
To generate ATPG patterns you need at least two Flip Flop, one scan_en input too.
ok! you want to use Tetramax to generate ATPG patterns.
But do you know what does these patterns?
ATPG patterns are used to ensure that the actual chips match the specification (netlist). That is to say they are applied by a tester to find chips with manufacturing defects.
