how to generate sinusoidal PWM...
kvrajasekar
Junior Member level 3
sinusoidal pwm
I am using 16f72 asm code to generate sinusoidal PWM.I not getting idea to start,Theory says that sine pwm can be generated by comparing sine and triangular waves.
I know how to use CCP module.can anyone help me how to do the same using software.
Please give me some ideas to start my project
sinusoidal pulse width modulation
I don't know about the PIC but generally it can be like this.
1. Based on desired frequency (fo) decide the Counter/Timer clock(fc) and Timer overflow rate(ft). ft = fc/MAX(timer value)
2. Make a table of the "PWM duty cycles" for the desired frequency. the number of entries in the Table will be n = ft/fo
3. Enable the timer for PWM output and interrupt on overflow.
4. On overflow of timer, program a new PWM value from table.
pwm sinusoidal
There are lots of PIC PWM examples at microchip.com
sinosoidal pwm
Thanks for the reply...
Mr AMK1971 given me good logic..i have tried using CCP1 in compare mode,but i didnt get the correct output.Is the pwm will be generated only using CCP1 in PWM mode?
My input freq is 50HZ and switching freq is 20khz.
sinusoidal pwm
check the link
rbsfm.ej.am/Downloads/APPNOTE/PowerControl/H1105.PDF
pwm sinusoidal microcontroller
The PWM generated by a microcontroller will give you a square wave, then you will need to apply a process to convert it to sinusoidal, like a filter.
make sinusoidal pwm
There is no need for that many entries. 0º to 90º table can be re-used in whole cycle.
pic program for sinusoidal pulse width modulation
Thanks for the above replies.I created 90 degree loop and inverted that according to the requirement.
