How to generate sdf file using RTL Compiler?
hlasy
Newbie level 5
RTL Compiler.
How to generate sdf file using RTL Compiler.
The write_do_lec I think does not do the job
Thanks.
rtl compiler sdf
Is this s-y-n-o-p-s-y-s tool ?
cadence write_do_lec
Cadence synthsis tool.
Help from command line.
rtl compiler sdf file creation
write_do_lec writes the script for formal verification with LEC/Verplex/Conformal.
RTL compiler is from cadence.
rtl compiler command line
Hi ,
Do you have spef from layout ?
I can give how we do in PT .
read verilog netlist and read parasitics and then write SDF .
I think similar steps for any other timing sign-off tools ?
Thanks & Regards
yln
RTL Compiler
Hello write_do_lec dosent writes out the sdf file. It writes out the dofile foe LEC.
Sumit
RTL Compiler
The Cadence delay calculator is CeltIC NDC. The command to produce an SDF file in CeltIC is "generate_sdf".
