How to generate .db file for standard cells from verilog file?
dhaval4987
Full Member level 3
AZ
Hello all,
I have a verilog file that has timing information for standard cells and I need to generate .db file for standard cells from it. Is it possible? how should I do it?
Thanks and regards,
Dhaval
First, you need to create .lib.
Second, if you can get rid of detailed functionality, you can just read .lib into DC and dump out as .db. If you need the functionality of the cell as well, you need Library compiler.
do you have any tutorial/manual that explains that?
Hello Dhaval:
I am curious to know about this. How have you created a the standard cell file with timing information?which tool does this?
Thanks in advance
