How to generate block level constraints from top level constraints in synopsys DC
akash singh
Newbie level 5
Newbie level 5
Hi all!
I have top level constraints for my design. I want to synthesize a particular block of my design for which I need to generate block level constraints using Top level constraints.
I am using synopsys design compiler.
I have heard about dc_allocate_budget command.
Can someone provide link for some tutorials on how to use dc_allocate_budget command for the purpose or any other better way to do that.
Did you check Characterization in DC?.
The allocated budgets can be used to drive the synthesis of individual blocks. The budget generation and allocation process is iterative.
You use the RTL budgeting flow to allocate initial budgets, then use the initial budgets to synthesize lowerlevel blocks. You can apply the synthesis results to the budgeter to derive more accurate budgets by using the gate-level or refinement budgeting flow, repeating this process until design goals are achieved.
