How to generate a uniformly distributed signal in Matlab?
leoren_tm
Advanced Member level 1
pls help me in matlab..
how can i generate a uniformly distributed signal with a specific mean and STD...
rand
this funtion generate a uniformely distributed signal with a 0 mean and 1 variance
while
randn
this function generate a normaly distributed signal, which you could chose its mean and STD..(standard deviation)
Re: pls help me in matlab..
MATLAB has subsystem SIMULINK for simulation of different systems.
SIMULINK has "Uniform Random Number" block for your task.
This block is placed in Simulink/Sources section.
Hi
Starting from a zero mean and unity standard deviation random generated numbe n, you can find what you want multiplying by the desired standard deviation std and adding the desired mean m, so that
New_n = n*std+m;
cheers
Sal
not in simulink....
Added after 1 minutes:
Sal said:
Hi
New_n = n*std+m;
cheers
Sal
wat do meean??? how can i use rand function with that??
A uniform distribution with a given "width" has a fixed variance , its not a parameter you can pick. You can however, set the width of your pdf (which will alter the variance). See picture below.
If you want to increase the variance, you can do it by increasing Delta.
As delta --> higher, variance goes up with the square of delta.
I believe typing "rand(1)" returns a number thats uniformly distributed between 0 and 1.
--> delta in this case is 1 , so its variance is 1/12. the mean is 0.5 .
If you wanted a uniform distribution with a variance of 9/12 , you can get the result by " 3*rand(1) "
why? well.. remember, variance scales with the square of the multiplication factor.
(the delta is 3 times larger... but variance is delta^2/12, so the variance increases by a factor of 9). Whats the new mean? its 3*0.5 = 1.5 . What if you wanted the mean to be some other number? simply add the different to 1.5 .
Suppose i wanted the new mean to be 2 (and variance of 9/12) , i would simply add 0.5 to the result.
newNumber = rand(1)*3 + 0.5
this has a pdf that looks like :
Sal is right... just that rand(1) doesnt return a 0 mean . But you can use 'rand(1)-0.5' and use what sal suggested.
Good luck
hmm...i was trying to generate a uniformly distributed signal, with a variance of 1.5, and STD of 3.2..
with a 128point...
what i did is use the function..
wgn
which i can set my parameters...[/quote]
Does "wgn" stands for white gaussian noise,
If it is so, then I think this function can be used to generate random number.
(noise is infact a random number).
However since it is white gaussain noise the mean will be zero or some particular constant value.
thanks
sarfraz
huh??the mean will not be zero....
what eecs4ever is saying translates into MATLAB code as
% Generate 50 uniformly distributed random samples
Xunif = rand(1,50); % 50 samples of a uniform dist
% with fX(x) = {1 when 0<=X<=1 and 0 otherwise}
% Define the desired means and variances
mu_Y = -100; % the desired mean of RV Y
var_Y = 5; % the desired variance of RV Y
% Define the mean and variance of fX(x)
mu_Xunif = 0.5;
var_Xunif = 1/12;
% Solve for parameters a and b
a = sqrt(var_Y/var_Xunif);
b = mu_Y - a*mu_Xunif;
% Transform the random samples from fX(x) to random samples for fY(y)
% where the mean and variance of RV Y was defined
Yunif = a*Xunif+b;
