Dear all, I am desperately looking for means to generate a geometry for power flow integration.
The problem is , if I draw a line in 3D modeler, then the line will appear in the list of geometry in field calculator. However, if I draw a rectangular or create an object from a subsurce of another object, the resulted entity doesnt enlist as a geometry in the field calculator.
I am trying to follow the field calculator cookbook " If the surface is only a subset of an object’s faces, or a slice through the entire plane of the model not already defined by a separate 2D entity, then a Faces List and/or Cutplane must be generated to represent the integration location." But how to do it?
