How to generate 32-bits Pseudo-Random Binary Sequence?
air2008
Newbie level 6
Beijing, China
hi,
I want to generate a 32-bits independently and uniformly distributed random binary number prbs[32:1]. One method is to use 32 seperate LFSRs to generate.
Could anybody can give some simple solutions?
air2008
rfmw
Advanced Member level 2
What is your desired PRBS length?
bibo1978
Full Member level 4
LFSR is the most simple pseudo random generators and it gives a psuedo-random white sequence, other techniques will generate other kind of random sequence it depends merely on the application, kind of random sequence (guassian,white ..), and PRBS length.
so what do u need ?
Ice-Tea
Full Member level 2
Belgium
Hmmm... What is your trigger? If it's totally non-related to your systems clock, and your system clock is much higher then your trigger event, you could just use a counter.
darylz
Full Member level 2
if you want to gen a prbs with len of 2^32-1, in fact, 32 bit registers is not a must. in fact, you could shift more than 1 bit per clock cycle. you caould refer to the byte based CRC circuit.
