How to force Synthesis tool use standard cell library MUX for implementing MUXs
makanaky
Full Member level 1
I am using RTL compiler to synthesize a critical path of MUXs, and the tool implements the MUX using gates (NAND, OR ... etc). I am afraid this may increase the path delay while the std cell library contains MUX cells. Is there a way to instruct the tool to use a std cell MUX instead of gates ?
use map_to_mux attribute or after elaborate map then with required libcells and mark them preserve
