How to force a signal to certain value from Verilog testbench?
gold_kiss
Full Member level 4
hi,
how do i force a signal to certain value from testbench. this signal is part of DUT and is deep inside the DUT hierarcy.
Thanks,
Gold_kiss
force signal in verilog
Pls use tb.dut_level1_dut_level2.dut_levelx.signal = value.
Good Luck
writing testbenches in verilog
yea i got this one ...
initial
begin
force tb_top.dut_top.dut_block.dut_signal = 1'b1;
#500 release tb_top.dut_top.dut_block.dut_signal;
end
thanks guys,
Gold_kiss
writing testbench verilog
you can also use assign deassign for reg
writing testbench in verilog
but what if the DUT was designed in VHDL?
writing verilog testbench
If the DUT was in VHDL, as such the language prevents you from doing this. However, simulators provide a mechanism to access internal variables in VHDL via VHPI/FLI - programming language interfaces. Which simulator do you use? I know MTI has SignalSpy (Spy is more for probing, but I believe they also have some thing to deposit value), NC has NC_MIRROR (NC_DEPOSIT).
Sometime ago I made a generci package (See http://www.noveldv.com/eda/probe.zip) that wraps these simulator specific calls into more generic ones, so that the user's TB code can remain simulator independent. I made this only for probing, but can easilyy extend this to deposit/force if there is enough interest in the community. Please email me @ ajeetha AT noveldv DOT com if you need this.
HTH
Ajeetha
force release verilog signal
I am confused for your opinion.
"assign" is for wire type.
We evaluate reg in "initial" in the testbench.
Good Luck
how to force a signal in verilog
Good Luck
There is also a "procedural assign" in Verilog - less used though.
Ajeetha
verilog force signal
Forcing internal signals in design is not a good testbench writing practice.
Try to minimize this as much as possible. This limits testbench reusability.
I mean there will be problem if you change design hirarchy or if instead of
rtl you want the same testbench for netlist.
verilog forcing signals
It's better to drive input signals to force interal signals.Driving interal signals directly is not good!
verilog deposit
your can use force ... release to do it
