how to fix WARNING:Xst:1710
tanish
Junior Member level 2
hello
I'm trying to simulate a simple ROM(read only memory) in ISE 14.7 but unfortunately I have a warning during synthesize xst.
WARNING:Xst:1710 - FF/Latch <data_out1_5> (without init value) has a constant value of 0 in block <ROM>. This FF/Latch will be trimmed during the optimization process.
I've seen a description in this link:
http://www.xilinx.com/support/answers/31856.html
but I use spartan6.
I guess what the problem is but how can I fix this?(before reset all registers values are undefined but after reset all of them set to zero and after that when I want to set a register with a zero value I have the mentioned warning.
this is my code:
Code Verilog - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
module ROM(
clk,
read_en,
reset,
address,
data_out0,
data_out1,
data_out2,
data_out3,
data_out4,
data_out5
input read_en, clk, reset;
input [5:0] address;
output reg [5:0] data_out0 ;
output reg [5:0] data_out1 ;
output reg [1:0] data_out2 ;
output reg [5:0] data_out3 ;
output reg [5:0] data_out4 ;
output reg [1:0] data_out5 ;
always @ ( posedge clk or posedge reset)
 begin
  if ( reset )
   begin
     data_out0 <= 6'b000000 ;
     data_out1 <= 6'b000000 ;
     data_out2 <= 2'b00 ;
     data_out3 <= 6'b000000 ;
     data_out4 <= 6'b000000 ;
     data_out5 <= 2'b00 ;
   end
  else
   begin
     if (read_en)
      begin
       case (address)
         6'b000000 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0000000000000000000010000011; //0
           6'b000001 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0000010000001100000110000000; //1
         6'b000010 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0000100000011000001010000101; //2
         6'b000011 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0000110000010100001110000110; //3
         6'b000100 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0001000000100000010010001011; //4
         6'b000101 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0001010000101100010110001000; //5
         6'b000110 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0001100000111000011010001101; //6
         6'b000111 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0001110000110100011110001110; //7
         6'b001000 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0010000001001100100010010000; //8
         6'b001001 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0010010001000000100110010011; //9
         6'b001010 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0010100001010100101010010110; //10
         6'b001011 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0010110001011000101110010101; //11
         6'b001100 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0011000001101100110010011000; //12
         6'b001101 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0011010001100000110110011011; //13
         6'b001110 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0011100001110100111010011110; //14
         6'b001111 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0011110001111000111110011101; //15
         6'b010000 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0100000010001101000010100000; //16
         6'b010001 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0100010010000001000110100011; //17
         6'b010010 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0100100010010101001010100110; //18
         6'b010011 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0100110010011001001110100101; //19
         6'b010100 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0101000010101101010010101000; //20
         6'b010101 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0101010010100001010110101011; //21
         6'b010110 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0101100010110101011010101110; //22
         6'b010111 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0101110010111001011110101101; //23
         6'b011000 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0110000011000001100010110011; //24
         6'b011001 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0110010011001101100110110000; //25
         6'b011010 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0110100011011001101010110101; //26
         6'b011011 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0110110011010101101110110110; //27
         6'b011100 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0111000011100001110010111011; //28
         6'b011101 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0111010011101101110110111000; //29
         6'b011110 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0111100011111001111010111101; //30
         6'b011111 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b0111110011110101111110111110; //31
         6'b100000 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1000000100000110000011000010; //32
         6'b100001 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1000010100001010000111000001; //33
         6'b100010 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1000100100011110001011000100; //34
         6'b100011 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1000110100010010001111000111; //35
         6'b100100 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1001000100100110010011001010; //36
         6'b100101 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1001010100101010010111001001; //37
         6'b100110 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1001100100111110011011001100; //38
         6'b100111 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1001110100110010011111001111; //39
         6'b101000 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1010000101001010100011010001; //40
         6'b101001 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1010010101000110100111010010; //41
         6'b101010 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1010100101010010101011010111; //42
         6'b101011 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1010110101011110101111010100; //43
         6'b101100 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1011000101101010110011011001; //44
         6'b101101 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1011010101100110110111011010; //45
         6'b101110 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1011100101110010111011011111; //46
         6'b101111 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1011110101111110111111011100; //47
         6'b110000 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1100000110001011000011100001; //48
         6'b110001 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1100010110000111000111100010; //49
         6'b110010 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1100100110010011001011100111; //50
         6'b110011 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1100110110011111001111100100; //51
         6'b110100 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1101000110101011010011101001; //52
         6'b110101 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1101010110100111010111101010; //53
         6'b110110 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1101100110110011011011101111; //54
         6'b110111 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1101110110111111011111101100; //55
         6'b111000 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1110000111000111100011110010; //56
         6'b111001 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1110010111001011100111110001; //57
         6'b111010 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1110100111011111101011110100; //58
         6'b111011 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1110110111010011101111110111; //59
         6'b111100 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1111000111100111110011111010; //60
         6'b111101 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1111010111101011110111111001; //61
         6'b111110 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1111100111111111111011111100; //62
         6'b111111 : { data_out0, data_out1, data_out2, data_out3, data_out4, data_out5 } <= 28'b1111110111110011111111111111; //63
       endcase
      end
   end
 end
endmodule
It is a warning. Determine if it is ok (it probably is) and then ignore it.
EDA tools often present optimizations as warnings. If you come from a SW background this will seem weird. Large designs have many warnings as a result.
In this case, bit index 5 of data_out1 just happens to be 0 for all 64 values in the ROM as well as the reset.
You can "fix" the warning by adding logic that breaks this optimization and sets this bit to 1 in a case that cannot occur in practice. This is not a good choice though. Basically, unlike SW, you should not attempt to get 0 warnings for HW designs.
Reactions: tanish
    tanish
