[SOLVED] How to find the Zth of this circuit?
D
darrenbkl
impedance
Hi , for this question, can anybody teach how to find the Zth of this circuit?
because of the L1, i dunno how to solve that,thx.
**broken link removed****broken link removed**
impedance
emm,I mean i want to find the thevenin equivalent impedance looking from the right side, can anybody solve tat for me?with complete working,thx very much
Re: impedance
Zth=R4//R3//(1/jwC2)//(R1+R2//jwL1)
Added after 40 seconds:
w=60Hz
Re: impedance
Please make the circuit diagram clear
impedance
You can use simulator ... For example multisim or proteus. Multisim is simpler.
If ur interested in calculation, you need to get formulas and equations. You may need a material to learn from.
Material:
http://www.ene.ttu.ee/leonardo/elektro_alused/
Itis in estonian but im pretty sure that if you want you will find what you are looking for..
Reactions: ramz
    ramz
Re: impedance
Whatever Saruman has written except ω=2Πf and not 60Hz.
Regards,
Laktronics
Re: impedance
Yeap. That's a classic mistake i always do. I keep omitting 2π when calculating impedance components (It has often led me to very wrong results, obviously).
Re: impedance (help me solve some problem) !!
I always confuse of the component that hang across the sky there,in this case is L1. so basically we paralled the component inside then only deal with outside right?
Added after 3 hours 17 minutes:
How about this two question,i know it is simple but i still cant figure it out.
1)Using Thevenin's Theorem,find the voltage across R4.
2)Simplify the circuit external to R3 to its Thevenin Equivalent.
Re: impedance
1)You must replace all of the circuit except the resistor R4 witn its thevenin equivalent, then the apply a voltage divider equation between R4 and the Zth of the rest circuit.
In this case,(with the voltage source short circuited) the Zth of the circuit neglecting R4 is:
Zth=R3//-jXC//(R1+jXL//R2)
In order to find the Vth one must open circuit the circuit left of R4 and calculate the voltage at the floating node as (Vs in normal operation):
Vth=Vs*(R3//(R1+jXL//R2))/(R3//(R1+jXL//R2)-jXC) (voltage divider too)
The voltage acrooss R4 is:
V4=Vth*R4/(R4+Zth)
Added after 10 minutes:
2)Again, short circuit Vs, then calculate the impedance seen from a,b as:
Zth=-jXC//(R2+jXL//R1)
As before, open circuit a,b (i.e. remove R3) and calculate the voltage Vab with Vs in normal operation (might need a little bit of calculations)
impedance
thx saruman for ur patient : )
about the bridge circuit,is there any rule associate with it?
Re: impedance
It would be pretty easy since with the removal of R3 there is no bridge at all from what concerns the thevenin equivalent. You can use 2-3 voltage divider equations to find Vth, finding VXL and VR2 and then adding them. In any case, if you are interested in calculating impedances of circuits containing bridge components, i think it would not be difficult either to find some examples or general relationships on google or wikipedia (i can't remember the relations right now).
Cheers,
vag
impedance
can anyone explain me how capacitor smooth out rectified voltage? I don't understand,in detail,how does the caps respond to the rectified dc voltage.
Does the smoothing cap must be electrolytic cap?
