Register Log in
How to find delay caused by longer Poly layer and how to reduce this delay
circuitking
Full Member level 4
Dear all, In my layout I have many transistors and their gates are connected directly with poly layer. I want to find the delay caused by this long Poly line, could you tell how can I find it?. If this is too much, what methods do I have to reduce it. I heard that I should keep poly to M1 vias, could you tell more about it. Thanks
dick_freebird
Advanced Member level 5
USA
If your tools*PDK support RC extraction then maybe
this gets done for you, and you just need to run a
simulation based on the analog_extracted (or
whatever) view.
Or, you go and measure poly squares and determine
poly doping -> poly sheet resistivity (poly may see
various dopings depending on what it's routed
over and "tagged" as - N+, P+, silicide, no silicide).
Just put that in each leg as a properly connected,
properly parameterized presistor and let the FETs'
gate load "be what it is" (for short haul routes over
field, net capacitance added should be trivial). If
you feel like the net is significant you can always
calculate fringing + plate line capacitance and
add as a pcapacitor..
Toggle Sidebar
