How to extract SPICE netlist from GDS file
vsop
Member level 2
east
Is there any tools is able to extract the netlist (in SPICE format) from the existing GDS file? Thanks in advance.
joe2moon
Full Member level 5
MOON
gds comparation calibre
Take a look at:
Verplex Conformal™ LVR (Layout vs. RTL)
h**p://www,verplex,com/products/lec_brochure_LVR.html
It extracts the SPICE netlist from GDS...
vsop
Member level 2
east
dracular lpe
after reading its brochure, i wonder it is able to extract the netlist from gds? it seems to be able to compare the netlist from gds w/ rtl code. i'm not sure if i'm right. besides, i prefer the one which is free, or shareware.
joe2moon
Full Member level 5
MOON
que es gds en pspice
I think...
Maybe you can try to search the RC-extraction tools :D
Since they should be able to do the lpe (layout parasitic extraction),
and export the SPICE netlist.
bastos4321
Full Member level 5
space
can you get gds from spice
Calibre LVS for simple devices and xCalibre for parasitics, Dracula LPE, etc, can do the job.
Bastos
tlihu
Full Member level 6
gds2 extraction tool
Is it possible to obtain netlist from GDS without the original technology file? :(
Hughes
Advanced Member level 3
extract rc info from gds
You should at least know the layer information and primary cell of the gdsII file.
ICdesign
Newbie level 2
how to writeout cdl by reading gds in calibre
1. get the layer information
2.make out the command file for extraction
3. do extraction
4. you will get CDL netlist (SPICE)
you can choose dracula, diva, herculas, Calibre or Ledit tools you like.
zay_74007
Newbie level 3
利用calibre gds2得到 hspice
I dont think it useful, because you can not understand the netlist extracted from the layout.
rakko
Full Member level 4
mozambic
extract spice from gdsii
if you have a complete gds netlist, you stream in your gds into astro, define your layer numbers, and VDD/VSS. Then, you can write out a complete netlist. All this works if your gds was extracted completely to begin with.
ttspice
Member level 3
Republic of Taiwan
spice gds
Use an old fashion tool: Cade*ce Dracula LPE
It can extract not only MOS but also R/C as long as you have the right command file.
mlxsae
Member level 3
extract spice netlist from gds
I recommend to use the C@dence tools however it can extract R/C but not
the resistances of the routing wires. Does anybody has eperiences with
post extracting this resistances? Is it possible with the c@dence tools?
Thnx!
S. 8)
shiowjyh
c in gdsii
Thnx!
S. 8)
As I known, the metal resistance is about 0.075 ohm/sq.
Compare to those equivalent resistance of MOS devices, it may omit.
However, the parasitic capacitance does not; loading will affect your transition time. This always happens on a submicron design...
In deep submicron, you may take care more parameters...
Currently, on 0.25um or above (>0.25um), C@dence Dracula seems has no extra options to done with a parasitic resistance. However, you may put an extra dummy metal layer to form a metal resistance if you want...
Regards,
mehello
Newbie level 6
lpe from gds
so many tools can do this, Hercules, Dracula,Apollo, Astro, this is a basic function for most backend EDA tools.
shelkerahul
Member level 4
Bangalore
netlist-to-gds
If u have gds netlist, then do the “v2lvs” in CALIBRE. I think this is the simplest way to write the spice netlist.
marksile
Member level 1
does pspice accept gds files ?
You can run LPE(in fact it is LVS) while you think from GDS netlist to SPICE netlist. But you should add some parameter in you .lpe file. i.e. cap, res etc.
flyankh
Member level 5
GDS -> SPICE
Hi,vsop
In fact you are in a reverse flow .The RC extract tools can not work without an original netlist.
And from now on there haven't any tools can build a readable netlist from GDS file as I know.But if the GDS is not too huge ,you can try to use them ,and try to handle it.
Regards
flyankh
skymusic
Member level 3
Re: GDS -> SPICE
NC-verilog is leader, powerful
Added after 6 minutes:
I know two way.
1, Use LVS tools(like calibre), before check lvs, netlist from layout is extracted.
2, Use extract-rc tools(like xcalibre, diva), can extract-rc without RC, when use xcalibre, hspice and spectre netlist can be generated.
