How to extract parameter of InterDigitalCapacitor using IE3D
MM_DEVILS
Newbie level 6
Hi Jian,
Can you please tell me how to extract the capacitance ( series and parallel ) and inductance ( series ) values of Interdigital capacitor using IE3D?
With Regards,
MM_DEVILS.
jian
Advanced Member level 3
Re: How to extract parameter of InterDigitalCapacitor using
Hi, MM_Deviel:
After simulation, MODUA will be invoked to display the s-parameters. Please select PROCESS->PI NETWORK EQUIVALENT and select SHUNT C AND R for both the SHUNT COMPONENT AT TERMINALS and SERIES COMPONENT BETWEEN TERMINAL. MODUA will find the 3 capacitors for you. The C-values will be frequency dependent. If you want to user frequency independent C and a series L for the SERIES COMPONENT BETWEEN TERMINALS, you may want to build the frqeuency independent model with the C's and the L and try to optimize it on MODUA. Best regards.
    MM_DEVILS
