How to extract frames from yuv file ?
amith
Member level 2
yuv frames
HI all
how do i extract frames from yuv file.
amith
Re: yuv frames
Hi amith,
Are u talking about interleaved or planar yuv frames bcoz there are lots of formats in which yuv pixels can be arranged like YUV420, YUV422, YUV400, YUV444, YUV4111 (all can be interleaved/planar)???
~R
Re: yuv frames
Hai,
In yuv format there is no header information and hence you just need to give the required offset (Frame Size) from the starting to get to you required frame..the offset will depend on the specific YUV format, whether it is 420,422 etc..In case of a YUV420 stream, the offset for each frame will be Frame_Width * Frame_Height for luma and (Frame_Width/2) * (Frame_Height/2) for each of the chroma components...
- matt
yuv frames
you have to know how many lines per frame there are in your yuv file. And how many bytes per line.
