how to export the data about time and fields in CST?
alionxj
Newbie level 6
I have question here. how to export the data OF the relation about field and time, after simulation with thansient solver in CST? Only I can get is the relation about fields and position.
Pushhead
Full Member level 4
If I understand correctly, you are using a field probe. Click on the desired signal and go to File->Export->Plot Data(ASCII). That should do it.
P.
alionxj
Newbie level 6
Thanks for your suggestion. I didn't set the field prob. I'll try
mpero
Member level 1
Hi Ali
If you dont see it its because you didnt define it prior to the simulation!
Go is Solve/probes
cheers
