how to export S-matrix from ADS
burton
Full Member level 3
Full Member level 3
How can I export the S-matrix to a s*p file from the simulation results by ADS schematic or Momentum?
Thanks a lot!
Hi burton,
If you right on the graph that contains your data, theres an option that says write file. I'm not sure if it has the s2p format but theres another way that should work.
There's a button on the graph window (file tool menu?) thats I think the rightmost on the line of buttons like file, edit and etc. You should be able to find a data file tool in the menu and that definitely sets you convert and write files in the format you need. And then you can import the file you want in another software.
Hope this helps.
Ananth.
window toolbar>open new data display
draw the s parameter desired versus frequency.
select the box of curve
file toolbar>export>ascii code
the content of S curve will be written in txt format,
choose the name of file
use the info in text file
