how to export file in cst
kyg
Member level 5
site:www.edaboard.com cst export
hello anyone.....
anyone know the step how to export the file in cst before fabricate
snkhan
Full Member level 6
Gods place
File->export
and then select the format u want to export (most probably in dxf and then import it in any CAD software.
kyg
Member level 5
i already export to dxf file but when i try open using autocad 2005 the design only can display is ground plane. should i save layer by layer or else?
thanks
snkhan
Full Member level 6
Gods place
I thinks when u export then u need to select which surface u want to export.
aw
Member level 3
hi,
did you align the uv plane of the local coordinate system with the plane which you want to export? You should do this and then export the dxf - should work then...
aw
